Activity Forums Apple Final Cut Pro Legacy changing the frame rate
  • changing the frame rate
    Posted by Damian Dunne on November 10, 2005 at 4:39 am
    hey there guys!
    If I import my media which is @ 25fps and then change my comp settings to sya 29fps, that does that also change the frame rate of my media?
    thank you in advance!
    D
    be the ball
    Shane Ross replied 20 years, 10 months ago 2 Members · 1 Reply
  • Shane Ross
    November 10, 2005 at 5:09 am
    Nope. What you are trying to do is convert PAL footage to NTSC.
    You are going to have to use the Standards Converter found at http://www.nattres.com ($100)
    I touted it heavily inthe post RIGHT BELOW this one.
