Activity Forums Adobe Premiere Pro Changing the default export filename?
  • Changing the default export filename?
    Posted by Ryan Rivard on June 23, 2015 at 2:07 pm
    Hello all,
    I was wondering if it was possible to change the default export filename? I know that you can click the filename and rename it to whatever you want, however, it defaults to the name of the sequence. I’m looking for it default from the description of the sequence.
    I work with a high volume of videos (average 55 per project) and we have a set in stone naming system. S1, S2, S3, etc for sequences, however, the filename that we ultimately end up using is the same thing that we type in the description (“Bobby talks about the time he went to the doctor”, etc).
    Does anyone know a way to set it so that when I export my media, it just defaults to the description?
    Thanks in advance, I know this is a long shot.
    Ryan
    Ryan Rivard replied 10 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
