Activity Forums Adobe After Effects Changing the colour of water
  • Changing the colour of water
    Posted by Michael Freedman on January 11, 2011 at 3:38 pm
    Hello everyone,
    Before I start I would like to say thank you to everyone who replies to this post. I am in need of some advice.
    I have a set of five video clips that have water dropping into the frame. The water is a very slight greyish colour but mostly transparent and the background is white. I am attempting to change the water to a different colour in each video eg vid 1 the water would be orange, vid 2 the water would be pink etc. I need to keep the background as white.
    I have tried playing around with the change color filter but I’m not getting much of a result. Can anyone recommend a way to do this? I also have some RGB colour pantones that I need to stick to but obviously working in video they would have to translate to YUV. I am new to after effects having come from an editing background, so if there is anyway to do this in final cut that would also be good.
    Many thanks,
    Michael, London, UK.
    Michael F
    Michael Freedman replied 15 years, 8 months ago 2 Members · 2 Replies
  • Tudor “ted” jelescu
    January 11, 2011 at 4:46 pm
    I would duplicate the clip, crush levels to get the gray to be darker and the white to a clean bright white and use that as an alpha to composite the original back on itself. That would give you the water on one layer that can be affected by using the Hue/Saturation to colorize.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Michael Freedman
    January 14, 2011 at 10:48 am
    Thanks for this. It seems there are many ways to achieve the same effect, both were useful
    Michael F
