Activity Forums Adobe After Effects changing the color of objects or text
  • changing the color of objects or text
    Posted by Dragica Posavec on November 15, 2011 at 4:35 pm
    Hello everybody!
    how can i achive changing colors of some shapes or text in time, ie. how to change colors with a certain color and order of that colors to appear in certain time but without other colors and tones (of the “color wheel”)in between ?
    i did try with layer – color overlay and with effects – hue saturation but i didn`t get result that i wanted
    i hope this question is not to much confusing as i`am as confused beginner in AE 🙂
    D.P.
    Arn Sweatman replied 8 years, 3 months ago 5 Members · 8 Replies
  • 8 Replies
  • Roland R. kahlenberg
    November 15, 2011 at 6:10 pm
    You can try Effect>Generate>Fill and choose a color. Then use Hold Keyframes (KFs) to jump from one color to the next.
    HTH
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
  • Michael Szalapski
    November 15, 2011 at 6:59 pm
    Or, if you want it to fade, you can have multiple copies with different colors and then animate the opacity of the top one.
    Alternately, you could set up a Tint effect with your two different colors and make your object fade from black to white and the Tint will be making it go from one color to another.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Dragica Posavec
    November 15, 2011 at 8:15 pm
    Finally this helped me a lot! Thanks so much for your help 🙂
    D.P.
  • Dragica Posavec
    November 15, 2011 at 8:19 pm
    Thanks for your answer and good advice i will try that too 🙂
    D.P.
  • Dragica Posavec
    November 15, 2011 at 8:39 pm
    Finally this helped me a lot! Hold Keyframes was the key, thanks so much for your help 🙂
    D.P.
    November 16, 2011 at 1:51 am
    You’re Welcome!
    You’re Welcome!!
    You’re Welcome!!!
    RoRK
  • Christine Gardiner
    October 24, 2017 at 5:41 pm
    Thank you very much for this!! Solves the exact thing I wanted to achieve as well, very helpful!
  • Arn Sweatman
    June 1, 2018 at 9:11 pm
    Brilliant….and simple. Thanks so much!!!
