Activity Forums Adobe After Effects Changing the color of flowers in a long tracking shot
  • Changing the color of flowers in a long tracking shot
    Posted by Garret Layman on November 28, 2017 at 9:43 pm
    I’m working on a shot and need to change the color of a lot of small white flowers to assorted colors. The shot is almost 15 seconds and has a lot of motion. There doesn’t need to be a rhyme or reason to the colorizing, just random assorted colors. So far the best way I’ve found to do this is to track the shot with the 3D camera tracker and create nulls based on the the points that are attaching to the white flowers. To color them I’ve been parenting an adjustment layer (set to Darken) to the null with a mask around the flower itself and using Hue/Saturation – colorize to adjust the color. This is a pretty tedious process give the sheer number of flowers so I’m wondering if there is a better way to do this. Any help would be appreciated. A few shots from the sequence are below.
    Garret Layman replied 8 years, 9 months ago 1 Member · 2 Replies
  • Garret Layman
    November 28, 2017 at 10:38 pm
    I was able to create a procedural matte to single out the flowers and change them all in color and it looks pretty good. Where I’m getting hung up though is the multiple colors aspect. The director wants an assortment of colors that vary from flower to flower while still leaving a a few white ones here and there. Given the amount of motion in the scene I can’t think of a way to do this without some amount of tracking and masking. I may have to resort to groups of color or something…
    Mac Pro
    2×2.66 GHz 6-Core Intel
    64 GB 1333 MHz DDR3
    NVIDIA Quadro 4000 2048 MB
  • Garret Layman
    November 30, 2017 at 4:44 pm
    To follow up on this, I ended up using the 3d camera tracking data to apply to solids that I placed in 3d space around the scene (pre-comped and set to color transfer) and used the procedural matte as a luma matte to only apply it to the white areas of the flowers. This was much faster than my original method though I couldn’t quite get the level of variety that I was initially after. That being said it still turned out well and the director is happy so I’m happy.
    Thanks Dave.
