Activity Forums VEGAS Pro Changing the capture data rate
  • Changing the capture data rate
    Posted by Zen on May 2, 2005 at 8:09 am
    Hi all, still new to Vegas but i’m loving it more and more 🙂
    Just one thing, is there a way of changing the data rate for capturing?
    At the moment I’m capturing 720x576Pal from DV cam, would like to get the highest quality possible.
    Zen replied 21 years, 4 months ago 4 Members · 8 Replies
  • 8 Replies
  • Mike Kujbida
    May 2, 2005 at 9:04 am
    If you’re capturing with firewire, you’ve already got the highest quality possible.
  • Zen
    May 2, 2005 at 9:46 am
    thankx for the quick response 🙂 So 3.4 Mgs/sec is the highest that can be captured? Somehow I thought it would be higher.
  • Rick Dolishny
    May 3, 2005 at 12:39 pm
    No, that’s about it.
    Sounds like you’re coming from the Avid/Discreet world where you can dial in your caputre rate. That’s not possible with firewire, you are in fact getting it as good as it gets.
    – R
  • Zen
    May 3, 2005 at 1:36 pm
    Thank you 🙂 and yes you’re right, been working with Digisuite LE for a long long time.
  • Wade Harrington
    May 3, 2005 at 11:47 pm
    I use LE also and did some side by side tests. I compared 10 megs per second and the DV 3.4 and could not see any difference. Except that the reds are really jaggie. I hate this about DV.
  • Zen
    May 3, 2005 at 11:58 pm
    Yes I know what you mean. But still I think it’s time to change for me, I find the ability of Vegas to work with any kind of footage absolutely fantastic.
    One thing though, Titling, I just don’t like Graffiti and as for the built in option it’s very very basic. I can only wish I had my TitleMotion working with this. What do you use?
  • Wade Harrington
    May 4, 2005 at 12:13 am
    I don’t use LE much anymore at all. I use Vegas(because of 24pa). I miss the realtime effects though. Vegas renders a little slow but is rapidly improving and network rendering rocks. I’m network rendering over a wireless and it works! I don’t like the titler either, and really miss Title Motion. I have not found a good one yet. I have heard Tim talk about Heroglypf 2(you can download a demo). I tried it and I don’t love it yet?? We need to pressure Title Motion. If they can support Premier Pro, then they should support Vegas. They are missing the boat!! If they had it, I would buy now!! It is the only thing that is not good about Vegas except for no Hardware support. Were you using Premier or Razor?
  • Zen
    May 4, 2005 at 12:26 am
    I was and occasionally still using Premiere 6.5 as P Pro is not compatible.
    It was a good setup for it’s time he he it’s more like a dinosaur now.
    At some time I worked with Edit too but discreet killed that one.
    From all the edit progies I worked with, I find Vegas has most features I’m looking for except the Plug ins.
    Things like TM and HFX are a bit of a disappointment. More than anything else though it’s TM that I miss. Shame!
    Last night I downloaded Graffiti 4 trial but I found it a soup of a program to work with.
