Activity › Forums › Adobe Encore DVD › Changing the behaviour of only the last chapter in a feature, Can it be done in Encore?
  • Changing the behaviour of only the last chapter in a feature, Can it be done in Encore?
    Posted by Matt Stoddart on March 19, 2013 at 1:04 pm
    I’ve been asked by a client to defeat the “skip to next chapter” command only of the last chapter of a feature.
    I’m sure this delving into scripting (if…then…) which seem to be Scenarist territory only but would love to know if this can be done in Encore.
    If I had a long enough fade to black near the final chapter point in the feature I could set up another timeline with different properties giving me the desired result, but that is a bit “IF”.
    Thank in advance.
    Matt
    Daniel Ludwig replied 13 years, 6 months ago 2 Members · 5 Replies
  • Daniel Ludwig
    March 19, 2013 at 5:31 pm
    Matt,
    could you please tell us what system you are using! PC or MAC? is this a allready muliplexed DVD?
    then you´ve got only a few options.
    cheers
    danny
  • Matt Stoddart
    March 19, 2013 at 5:41 pm
    Hi Danny,
    Adobe Encore CS6 on PC and Mac.
    This is at the building stage before creating the DDP images for the replicators.
    Matt
  • Daniel Ludwig
    March 20, 2013 at 7:52 am
    ok,
    if you are about to mux your stuff, you could easiely use DVD AfterEdit Mastering Edition on MAC to tweek the muxed content.
    https://rivergatesoftware.com/dvdafteredit
    be awared that this software is running only on MAC OS systems prior 10.7 meaning 10.6 and 10.5.
    you could edit the DVD-code and create DDP-images also.
    there´s a freeware called mydvdedit, which could not create DDP-images.
    for PC there is a similar application, but can´t remember the name at the moment.
    cheers
    danny
  • Matt Stoddart
    March 20, 2013 at 11:02 am
    Thanks Danny for that, it’s two steps forward and 1 step sideways,
    the only Mac I work on is running 10.8, and everything else is PC, I might have to buy an old G4 to run mydvdedit, it looks very interesting.
    The PC software wasn’t Ifoedit? was it, if you do remember please drop me a line.
    It was nice to know that I didn’t miss any little trick in Encore and it has to be done using a different programme.
    Once the DVD info is edited I can always make a DDP image using Gear Pro.
    Matt
  • Daniel Ludwig
    March 20, 2013 at 11:24 am
    Hi Matt,
    yes, correct – that was ifoedit. 🙂
    to use gearmaster for DDP is a very good choice.
    cheers
    danny
