Activity › Forums › Adobe After Effects › Changing the beginning vertex of a mask…
  • Changing the beginning vertex of a mask…
    Posted by Miller on July 9, 2005 at 9:40 pm
    I’ve imported a mask from Illustrator and need to change the “beginning” point for a stroke. There’s a way to do this, no?
    AE 6.4
    Mac OS 10.4.1
    G5 dualie
    David Johnson replied 21 years, 2 months ago 3 Members · 3 Replies
  • Mike Clasby
    July 9, 2005 at 9:58 pm
    With the Selection Toll (V), select the vertex you want to become the first vertex, by clicking on it or drawing a little marquee around it. It’s selected when it beocomes a solid square and the little handles appear. Right click and choose “Set First Vertex”.
    Fini.
  • Miller
    July 9, 2005 at 10:08 pm
    Right click on a Mac…you mean Control click for me, perhaps? Ah yes, that’s it. I was missing selecting just the single point. Many Thanks!
  • David Johnson
    July 9, 2005 at 10:22 pm
    In your comp view options, make sure show masks is checked, select the point you want in the comp window and go to menu selection Layer>Mask>Set First Vertex (it’ll be grayed out if you’ve selected more than one point at a time). If you’re on a Mac, the process is pretty much the same, but I don’t recall the details since I’m on a PC at the moment.
