Activity Forums Adobe Premiere Pro Changing the aperture during a shot
  • Changing the aperture during a shot
    Posted by Karen Avizur on March 7, 2015 at 11:33 pm
    The adjustment of aperture while filming has become a regular occurrence in the weddings I’ve been editing, and it’s become infuriating, mostly because I don’t know how to fix it (and the fact that I shouldn’t have to, obviously). It’s just a flick left or right, sometimes as a bridesmaid is walking down the aisle, etc, and I’m not good enough at color correction yet to keyframe it back to normal. Anyone encountered something like this and found a reasonably easily doable fix for this? I’m on Premiere CS6 and using internal color correction tools, but if it would be easier to use another program, I’d be open to it.
    Karen Avizur replied 11 years, 6 months ago 4 Members · 8 Replies
  • 8 Replies
  • Mark Landman
    March 8, 2015 at 8:39 pm
    set the camera iris manually instead of using auto iris.
    Mark Landman
    PM Productions
    Champaign, IL
  • Karen Avizur
    March 8, 2015 at 11:22 pm
    They’re not using auto-iris. It’s on manual. It’s just that they futz with it ever once in a while. And I’m not asking how to fix it while they’re filming; I’m asking if there’s a way to fix it on post.
  • Shane Ross
    March 9, 2015 at 1:41 am
    There is no reasonably easy way to fix this. Gotta keyframe and fix with the color corrector, and it won’t be perfect. You can only make it less distracting.
    Best solution is to tell them NOT to futz with the iris while recording.
    Shane
    Little Frog Post
  • Karen Avizur
    March 10, 2015 at 2:12 am
    Blergh, oh well. Thanks!
  • Andy Lewis
    March 10, 2015 at 3:00 pm
    If you’re going to keyframe changes, I’d suggest doing it by looking at scopes (YC waveform) rather than the image.
    Are they static shots? I’d assume not if the operator was changing settings. If they are static though, you could crop the image to a continous area like a wall and keyframe to keep that line on the scopes in the same place.
  • Andy Lewis
    March 10, 2015 at 3:07 pm
    One final thing. As well as asking camera operators to try not to knock the aperture during shots – ask them to get a couple of minutes of cutaways for every scene – the flowers, close ups of faces, guests in silhouette against a window. Then you can cut to those whenever the shot goes wrong. Apologies if you’re well aware of the above and it’s just too late.
  • Andy Lewis
    March 10, 2015 at 3:17 pm
    Honestly the last suggestion (I quite like shot fixing). Sometimes the cure is worse than the disease – you’ve kind of fixed it so the brightness shifts are less extreme but they now look more unnatural and distracting. In this case, duplicate the layer with the corrected version on top and lower the opacity until the changes become less obvious.
  • Karen Avizur
    March 13, 2015 at 3:27 am
    All good ideas, thanks! 🙂
