Activity › Forums › Adobe After Effects › Changing Text
  • Changing Text
    Posted by Fred Matthews on June 14, 2007 at 4:01 pm
    Is there an effect that will show a word and then it cascades down to form a new word. Kind of like the Raining Characters but it changes the word from one to another on screen. The words are both five letters in length.
    Fred Matthews replied 19 years, 3 months ago 3 Members · 3 Replies
  • Darby Edelen
    June 14, 2007 at 5:13 pm
    I believe you will need to keyframe your Source Text property to achieve this.
    Darby Edelen
    DVD Menu Artist
    Left Coast Digital
    Aptos, CA
  • Roland R. kahlenberg
    June 14, 2007 at 6:57 pm
    Since it’s only five characters, it’s quite easy to do it one letter at a time. One text layer for each character, using Character Offset as the Animator property. Use Echo within an Adjustment Layer to achieve the Raining effect. Goto https://www.asciitable.com to check on the values you have to input for Character Offset. As a guide for reading the table, Zero is character value 48.
    Keyframing Source Text will end up with a ‘flash’ frame when the Source Text value changes – not as elegant as it can be.
    HTH
    Roland Kahlenberg
    https://www.broadcastGEMs.com – Adobe After Effects project files
    https://www.myspace.com/rorkrgbspace
  • Fred Matthews
    June 14, 2007 at 9:53 pm
    Thanks Roland that worked. I forget about the character offset because it isn’t a look I use much but it fit in this case.
