Activity Forums Adobe Illustrator Changing Text Transparency to Color
  • Changing Text Transparency to Color
    Posted by John Corbett on March 3, 2012 at 4:25 am
    I’m embarrassed both that I can’t figure out how to do this inside Illustrator but that I also can’t seem to enter the right search parameters in Google to find a way to do it, so I must turn to the Creative Cow Community for what is hopefully a very simple answer to a fairly basic question.
    I’m using some blocky/balloon text, a font called Pinewood if you’re familiar with it, the kind that has dead space in addition to color. While I can change the color of the text without difficulty, I can’t seem to figure out a way to change the transparent dead space to another color. Here’s the font:
    https://www.dafont.com/pinewood.font
    If you view it, you’ll see that the “knots” and “bark” are black and the “wood” is apparently white. In Illustrator, the white is actually transparent. Is there a way to change it from transparent to color? Say, black for the bark and red for the wood? I’ve tried creating clipping masks and outlines, but everything I do seems to only key off of the black. Thank you in advance for any assistance you can offer!
    Adolf Witzeling replied 14 years, 5 months ago 2 Members · 5 Replies
  • Adolf Witzeling
    March 3, 2012 at 4:09 pm
    it’s fairly simple:
    1) convert the font to outlines.
    2)select the converted font.
    3)with the font selected go to …,
    and while everything still selected GO TO
    4) go to and select . Now you should be able to see and select the formerly transparent areas only with your selection tool and color it to your likening.
    hope that helps.
  • John Corbett
    March 3, 2012 at 6:58 pm
    Hi Adolf,
    Thanks so much for responding. I attempted this last night, but any color changes I make to the transparent area affect the entire outline group, so I decided this wasn’t going to work. However, on your advice, I tried again, and realized that if I copied the transparent areas and pasted them OUTSIDE the outline group, I was able to change their color without difficulty. It’s clunky, but it’ll work. Do you or anyone else know of a way to change the color of the transparent area while it’s inside the outline group? That would be much easier. Thank you again!
    – Jc3
  • Adolf Witzeling
    March 4, 2012 at 3:30 pm
    lets do it again.
    1: convert font to outlines.
    2: select everything and go to…object…compound path….RELEASE.
    3: with everything selected…UNGROUP.
    After that the transparent parts are selectable with the selection tool.
    cheers
  • John Corbett
    March 4, 2012 at 6:54 pm
    That did it. Your original post didn’t have the crucial step that involved going to OBJECT -> COMPOUND PATH -> Release. That was an amazing fix! Thank you so much for your help, I am very grateful for the assistance!
  • Adolf Witzeling
    March 5, 2012 at 2:37 pm
    I’m glad you got it worked out. Yes my original post didn’t have the crucial steps because I put those in “tags” and when posted the contents of the tags got stripped off…my bad.
    cheers
