Activity Forums Maxon Cinema 4D Changing Text Dynamically – Like a counter
  • Changing Text Dynamically – Like a counter
    Posted by Pravin Chottera on August 25, 2009 at 10:10 pm
    I to make extruded text to change over time – like a counter that counts down over time – but the text has to be 3d and changing. Is there a way to do that?
    Brian Jones replied 17 years, 1 month ago 2 Members · 1 Reply
  • Brian Jones
    August 25, 2009 at 11:47 pm
    if you put the Text Spline object in an Extrude Nurb you can either keyframe the content of the Text Spline or feed in content with xPresso
