Activity Forums Adobe After Effects Expressions Changing text color into an expression
  • Dan Ebberts
    November 25, 2016 at 7:43 pm
    One way that should work would be to add a Fill Color Animator, change the Range Selector’s Units to Index, and use this expression for Start:
    text.sourceText.length-1
    and this for End:
    Dan
  • Olivier Mercier
    November 26, 2016 at 7:44 am
    Thanks, I’ll try it
  • Olivier Mercier
    November 26, 2016 at 10:01 am
    Dan, as I said I’m a beginner at coding expression
    What is a “Fill Color Animator” ? An effect, an expression? I havent’ find it both categories
    I can’t find where to paste your expression
    Thanks your help
    Oliver
  • Dan Ebberts
    November 26, 2016 at 4:55 pm
    If you twirl open your text layer, you should see an Animate dropdown where you can select Fill Color (then RGB). That will create a Range Selector, which has the Start and End properties, where the expressions go. If you twirl open the Advanced section of the Range Selector, you’ll see the Units control, which you should set to Index.
    Dan
  • Olivier Mercier
    November 26, 2016 at 6:59 pm
    Thanks Dan ! It’s perfectly workin’
    Now I can move on with my project ?
    Thanks a lot !
    Oliver
  • Kevin Mones
    April 8, 2018 at 11:19 pm
    Reviving an old thread. wanted to change the last character of my text to a different colour. This works perfectly
    end
    However, if my text has a soft return (multiple lines) the expression doesn’t carry to the next line.
  • Dan Ebberts
    April 8, 2018 at 11:44 pm
    Try this:
    txt = text.sourceText;
    txt.length – txt.split(/\r/).length
    Dan
