Activity Forums Apple Final Cut Pro Legacy Changing Text
  • Posted by Bob Hanson on July 20, 2010 at 6:54 pm
    I am trying to change some text in Boris and have the changes apply globally to all of my sequences. I seem to only be able to change one at a time. I’ve tried opening the text page by right clicking from the timeline and also by dragging it from the bin. Both will change, but not for all sequences.
    Bob Hanson
    Bob Hanson replied 16 years, 2 months ago 3 Members · 3 Replies
  • Jerry Hofmann
    July 20, 2010 at 9:12 pm
    It has to do with how you put the files in various sequences. If you nest a text file, then edit from the actual nested sequence by dragging it from the browser or Viewer to the same or new sequence it will be linked to the original, and all changes done to the original will ripple throughout. However, if you copy the nested clip from one sequence to itself, or to another sequence, it loses this affiliation.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • Michael Gissing
    July 20, 2010 at 11:58 pm
    You need to be more specific Bob.What do you need to change. If it is positional then you can use the motion tab to make those changes and then paste attributes to all the other clips.
    That can be done to a nest as well. If it is the text inside Boris, then I suspect it will be a clip by clip exercise. I have read of XML based editing of text attributes like size and font but I am not sure if that works with Boris content.
    Try a search of this forum as I am sure this has been dealt with before.
  • Bob Hanson
    July 21, 2010 at 7:04 pm
    Trying to replace some characters in one sequence and have it apply to multiple sequences. I’m going to give nesting a try. My thanks to both of you.
    Bob
