  • Posted by Sonia Li on September 5, 2017 at 9:47 pm
    Hi everyone! I’m new at using expressions and After Effects, so bear with me here.
    I am having trouble figuring out how to use the speed expression. I have a Math.sin(time)*10 expression that someone kindly helped me with, and I’d like to add speed to the animation. Currently, the animation moves back and forth in a limited range, but I cannot change the speed without keyframe. I’d like to avoid keyframe to gain more flexibility.
    Would love some pointers. Thanks so much!
    Best,
    Sonia
    Dan Ebberts replied 9 years ago 2 Members · 3 Replies
  • Dan Ebberts
    September 5, 2017 at 10:23 pm
    If you just want to be able to set the speed to some other value, you could do something like this:
    s = effect(“Slider Control”)(“Slider”);
    Math.sin(time*s)*10
    where setting the slider to 5, for example, would make it oscillate 5 times as fast.
    If you want to animate the speed, that’s a more difficult issue, and you should probably check this out:
    https://motionscript.com/articles/speed-control.html
    Dan
  • Sonia Li
    September 6, 2017 at 6:41 pm
    Dan, thanks so much for this! I tried putting the expression into Rotation but it gave me an error. Sorry, please bear with me, I’m very new at this. Not sure where I can put in this expression. Thanks again!
  • Dan Ebberts
    September 6, 2017 at 6:46 pm
    That expression is for the Position property.
    Dan
