Activity › Forums › VEGAS Pro › Changing speed without the obvious fade result
  • Changing speed without the obvious fade result
    Posted by Derek Hammer on March 10, 2016 at 4:52 pm
    Hi there,
    I sped up some footage but it always looks obvious because of the movement. It’s hard to describe but just the movement between frames. For example, it seems that when it goes from frame 1 to frame 2, there’s still a trace of frame 1 there. Any ideas? Is it about disabling resample?
    I appreciate it!
    John Rofrano replied 10 years, 6 months ago 3 Members · 2 Replies
  • Wayne Waag
    March 10, 2016 at 5:19 pm
    Probably. Disable resample for those events and see if it’s better.
    wwaag
  • John Rofrano
    March 17, 2016 at 11:25 am
    It sounds like “fading between frames” is really Frame Blending that happens because of Resampling. If you Disable Resample this should stop.
    ~jr
    http://www.johnrofrano.com
    http://www.vasstsoftware.com
