Activity Forums Apple Final Cut Pro Changing speed of clip without rippling..
  • Changing speed of clip without rippling..
    Posted by Chris Harder on June 27, 2011 at 1:13 am
    if i have a clip in the timeline with a duration of 5 seconds and i want to modify its speed to 50% without rippling its length..Is the any way to do this??
    Simon Ubsdell replied 15 years, 2 months ago 4 Members · 4 Replies
  • Geoff Dills
    June 27, 2011 at 9:26 am
    Try “lifting” the clip to a secondary storyline, putting it above the main storyline, retime, trim, replace.
    Best,
    Geoff
  • Simon Ubsdell
    June 27, 2011 at 11:40 am
    [Geoff Dills] “Try “lifting” the clip to a secondary storyline, putting it above the main storyline, retime, trim, replace.”
    Yeah, that’s how I do it was well but it’s quite a lot of extra work. It’s just a shame (and quite ironic) that they finally addressed this long-standing problem in FCP7 and then forgot to implement something similar here!
    Simon Ubsdell
    Director/Editor/Writer
    http://www.tokyo-uk.com
  • Bradinn French
    June 27, 2011 at 5:42 pm
    I was also looking for this, I hope it doesn’t take them another 7 versions with this interface before they re-implement. Before FCP7, the way I had always done it was through temporal keyframing. Am I correct that we cannot keyframe timing in this current iteration? I haven’t found a way in program and a quick forum search looks like we only have the simple ramp function…
  • Simon Ubsdell
    June 27, 2011 at 7:37 pm
    [Bradinn French] ” Am I correct that we cannot keyframe timing in this current iteration?”
    Sadly I’d say you are correct at this stage, although to be fair they probably think they’ve given you enough tools to kinda do the job.
    Only they kinda haven’t, sorry!
    Simon Ubsdell
