Activity Forums Adobe After Effects Expressions Changing specific keyframe that holds color value using expressions
  • Changing specific keyframe that holds color value using expressions
    Posted by Ivan de Wolf on July 20, 2022 at 3:31 pm
    Hi! I have been trying to adjust a keyframe in an animation that holds specifically a color value, so I can control that color state via a controller of some sort. I know there are ways to manipulate key values using the ‘linear()’ function, but somehow it doesn’t work on color values…Probably because the value type is not something that can be scaled? The error I get is: “ERROR: Argument 1 to linear() must be scalar”
    Here is my current code:
    t1 = key(1).value;
    t2 = key(2).value;
    v1 = 0;
    v2 = hexToRgb(“739C8A”);
    linear(value,t1,t2,v1,v2); <—- This part doesn’t work!
    }else value
    Any help would be much appreciated! Thank you!!!
    Michael Mathes replied 4 years, 1 month ago 3 Members · 2 Replies
  • Dan Ebberts
    July 20, 2022 at 3:47 pm
    I think you’d want to set it up like this:
    t1 = key(1).time;
    t2 = key(2).time;
    v1 = hexToRgb("0");
    v2 = hexToRgb("739c8a");
    linear(time,t1,t2,v1,v2)
  • Michael Mathes
    August 2, 2022 at 11:49 pm
    The scalar error you’re getting is because your v1 variable is only supplying 1 value when it needs 4 for a color value. So you could also use [0,0,0,0] as your v1 value. I’ve run into this issue enough times that I thought it might be helpful to share what the error means.
