Activity › Forums › Apple Final Cut Pro Legacy › Changing size of Clip
  • Changing size of Clip
    Posted by Jimy Bleu on September 25, 2006 at 12:49 pm
    Is there any way to lower or raise the size of a clip in a FCP project, rather than wireframe zooming?……….for instance, with a picture file, you can re-size the file in the photo editor.
    I have a few clips that were shot way too wide & too close. I need to somehow re-size them. If I use the motion/wireframe on them to zoom them in smaller, they violate the ‘title safe’ area.
    Thanx
    Jerry Hofmann replied 20 years ago 2 Members · 1 Reply
  • Jerry Hofmann
    September 25, 2006 at 12:57 pm
    There’s no way to make a shot which is too tight to loosen up. if you push it back there’s no video to fill the screen around it. You can push into a clip, but you can’t pull out. If you expand the video more than about 110% (pushing in on a shot which is too wide), it will pixelate pretty badly.
    I’d suggest a reshoot would solve your problems.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
