Activity › Forums › Apple Final Cut Pro Legacy › changing settings from sd to hd
  • changing settings from sd to hd
    Posted by Bogdan Stoica on December 8, 2008 at 10:01 pm
    hello,
    I just realized i was doing somethingwrong while editing my project.
    I shot hd video (well…1280×720) that i downloaded from my cards to the computer. When i started editing, i didn’t realize my sequence settings were set to 720X480. So, when I change the settings to HD, everything i edited remains at SD resolution – i get my picture surrounded by a black frame.
    Could anyone help me with this problem? thanks a lot!
    Bogdan Stoica replied 17 years, 9 months ago 2 Members · 2 Replies
  • Matt Larson
    December 8, 2008 at 11:11 pm
    Duplicate your sequence that has the 720×480 settings to keep as a backup in case you screw something up.
    Next, right-click your sequence in the browser and select “Settings”
    In the bottom left corner of the window that opens, you will see “Load Sequence preset”. Click it and choose the correct preset. You will probably be warned your editing timebase will not be changed.
    Now you have the proper sequence settings (except for timebase) and your video surrounded by black. Select all of your clips and choose “Remove Attribute”. Choose Basic motion and distort. Click OK.
    You should now have full frame HD video.
    Finally, select all of the media in your timeline. Hit “cmd+x” to cut ALL media from your timeline. Right click on your sequence in the browser again and change the frame rate to the frame rate you need it to be (probably 59.94 for 720p). Click OK. Paste all of you media back in to the timeline bu hitting “cmd+v”
    I know some of that may seem redundant, but it’s important to make sure you use a sequence preset so you don’t introduce other problems.
    2 x3Ghz Quad MacPro
    9 GB RAM
    Mac OS X 10.5.5
    QT 7.5.5
    FCP 6.0.5
    AJA Kona 3 (6.0.1 drivers)
    G-Speed XL 12 RAID
  • Bogdan Stoica
    December 9, 2008 at 3:23 am
    Thank you so much! It worked great! Thank you!you saved me from re editing my film 🙂
