Activity Forums Adobe Premiere Pro Changing sequence type
  • Changing sequence type
    Posted by Roberto Cerini on December 14, 2009 at 10:51 am
    Hi – I just imported two avi’s in permiere (different camera angles). One of them is 720×480 and the was other 1920×1080. I re exported the 1920 one to match the 720 and re imported it into my project, EXCEPT… I put it into the Sequence that premiere had created for the 1920 sequence and did all the edits. How can I change the Sequence setting to be 720? I can’t find a way? Do I need to start all over again with a new sequence with her right settings (I hope not)?
    Roberto Cerini
    https://www.robertocerini.com
    Vince Becquiot replied 16 years, 9 months ago 2 Members · 1 Reply
  • Vince Becquiot
    December 14, 2009 at 5:19 pm
    in CS4, Create a new sequence with the right settings.
    Double click on it in the project panel and drag the old sequence into the new one, then scale accordingly.
    You can also copy and paste all the clips from one sequence to another in order to keep the edits, but you will have to resize every clip.
    In CS3, create a new project and import the old one.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
