Activity Forums Apple Final Cut Pro Legacy Changing sequence settings for editing?
  • Changing sequence settings for editing?
    Posted by Brad Hebert on April 6, 2012 at 10:35 pm
    I’m familiar with offline editing, where the video files are smaller with matching sequence and then reconnect the hi-res footage later. But I’m curious if it’s ok to simply change the sequence setting, in my case from ProRes to HDV, in order to render faster while I’m editing, and then change the sequence back to ProRes and re-render for final output. Will that cause any problems? I’m staying 1080p/24, but just changing the codec. Also, there is chroma keying involved.
    Brad Hebert replied 14 years, 5 months ago 3 Members · 3 Replies
  • Steve Eisen
    April 7, 2012 at 2:13 am
    I would not recommend what you want to achieve. I would recomend ProRes the whole time. HDV is very processor intense due to its Long GOP codec.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • Shane Ross
    April 7, 2012 at 5:04 am
    Agreed. Rendering is ProRes gives better results, and should be quicker.
    Shane
    Little Frog Post
  • Brad Hebert
    April 8, 2012 at 3:22 am
    Thanks for the info. I’m also curious:
    If my main sequence and footage is 1080 ProRes HQ (mainly because of green screen), but I have other low-quality home-footage to add. Can the home footage be 480p ProRes LT to save space? Or should it be converted to 1080 HQ?
