Activity Forums Adobe Premiere Pro changing sequence length
  • changing sequence length
    Posted by Grzegorz Kwiatkowski on September 2, 2014 at 9:02 am
    Can I somehow change the sequence length? I would like to shorten it because the actual clips take less space than the sequence total length. When I put the sequence on the main sequence it is just too long.
    Gene Weglarz replied 11 years, 11 months ago 2 Members · 1 Reply
  • Gene Weglarz
    September 2, 2014 at 1:10 pm
    Usually the sequence length defaults to the actual length of the sequence. One gotcha that has gotten me a few times is a lone clip stuck some where further down the timeline that I can’t see. If that’s the case, delete the clip and the sequence should go back and default to the actual length.
    Otherwise adjust your work area to the sequence length.
    Geoffrey Weglarz
