Activity Forums Adobe After Effects Changing selection size for transformations in a layer
  • Changing selection size for transformations in a layer
    Posted by Lou Smith on July 28, 2014 at 6:54 am
    I want to use Bezier Warp and other transformations on various layers in a composition. However, each layer has the same transformation box size– that is, the size of the biggest layer, and that’s a problem when some of the layers are pretty small. Is there a way I can shrink down the box sizes to fit each of the smaller layers and allow for more maneuverability?
    Also, I’m using After Effects CS3 if that matters.
    Thanks.
    Michael Szalapski replied 12 years, 1 month ago 2 Members · 3 Replies
  • Michael Szalapski
    July 28, 2014 at 3:42 pm
    Where did these layers come from?
    If you imported them from a Photoshop file, try importing again and look more carefully at the importing options. Specifically the part where it talks about layer sizes…
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Lou Smith
    July 29, 2014 at 4:59 am
    Ah, I see. If I import with “cropped layers” it doesn’t seem to be a problem. Thank you!
  • Michael Szalapski
    July 29, 2014 at 11:50 am
    Yay! Glad that solved it.
    – The Great Szalam
