Activity › Forums › Adobe Premiere Pro › Changing Screen Zoom or Font Size
Posted by Sean Welski on August 29, 2020 at 8:15 pmHey group,
I have a wonderful editor I’d like to use but her eye sight isn’t what it used to be. Is there any way to make the 1. font size larger 2. overall screen size larger, etc.? 3. Any settings to help her out and be able to work? Any tips in this regard would be HIGHLY appreciated. She’s cutting on a Mac in Adobe Premiere Pro 2020.
Thanks so much.
With respect,
SeanJim Curtis replied 6 years ago 6 Members · 6 Replies -
Alex Lau
August 30, 2020 at 3:41 pmThe beautiful thing about Premiere Pro is that each panel can be dragged to anywhere. If you use a second monitor, you can drag the timeline to the 2nd monitor and resize it to fit the entire monitor. If timeline is your issue, you may want the second monitor to be 32″ or 40″ so you can greatly enlarge the timeline.
For the playback display, Ctrl+~ would fully display the source, or the program panel.
Daniel Carranza
August 31, 2020 at 12:08 amHello, Sean.
That’s very kind of you. Adobe’s font sizes are very small indeed. I did a quick research here and I couldn’t find a solution inside of Premiere.Did you try to solve it using Windows tools? I’m sure there’s a way of doing that through the Operational System. Just type “eye control settings” in your search bar and you will find it.
Check it out:
Best wishes,
Daniel Carranza
Sean Welski
August 31, 2020 at 2:03 amThank you for the reply but she’s editing on an iMac.
Best,
Seam -
Gary Milligan
August 31, 2020 at 11:56 pm -
Ann Bens
September 1, 2020 at 11:05 amWith all due respect but my eye sight is not what it used to be but I now use glasses.
Adobe Certified Expert Premiere Pro CS2/CS6/CC
Adobe Community Professional -
Jim Curtis
September 3, 2020 at 12:27 amIf you and your friend don’t know about this, it will change your life:
On System Preferences>Accessibility>Zoom, click the checkbox for “Use Scroll Gesture with Modifier Key to Zoom.” The default setting is the Control key.
Then, when you want to zoom in and magnify the screen, hold down Control and use your mouse wheel or finger on a Magic Mouse to scroll up, and the image will magnify centered on your mouse pointer location. Do the reverse to zoom back.
On a laptop without a mouse, there’s a key combo that does a similar thing. I think it’s Cmd-Opt-+ and Cmd-Opt–, but I’m going from memory and not on a laptop as I write this.
Jim Curtis
jamesphilipcurtis.comMacPro7,1 24-core – 256 GB RAM – AMD Radeon Pro Vega II 32 GB – 10.15.6
