Activity Forums Apple Final Cut Pro Legacy Changing scratch disks
  • Changing scratch disks
    Posted by Darryl Thomson on August 7, 2007 at 3:33 pm
    I am keen to keep the project files and capture and render files for a project together in one set of folders on a portable external drive. Is there a way to tie the scratch disk setting in Final Cut to a project? And/or easily set the scratch disk?
    There seems to be the ability to set numerous scratch discs but how do you easily choose between them?
    Final Cut seems to only pick up the top setting. Do you really have to laboriously check whatever the previous editor has left set. One by one remove all his settings and then add yours. Remembering of course to then set it back to the way you found it.
    Can one not be set as default and if several scratch disks are set, can the specific one you want for that project be chosen from a list? Final Cut forgets an external drive soon as it finds its not there, so you need to add it each time.
    If you have to do it the laborious way, can this be done with a macro?
    Dazzer
    Tom Matthies replied 19 years, 1 month ago 3 Members · 2 Replies
  • Timebombtim
    August 7, 2007 at 3:44 pm
    for the most part, yes you do, as far as i know, no presets…many people set their scratch disks to one location and then within those folders have their capt, render, thumbs, etc. named after their project.
    but to keep in a seperate local, you will have to “laboriously” check them out. step one of editing in FCP as i know it.
  • Tom Matthies
    August 7, 2007 at 9:14 pm
    Or set the machine up with different Users who all have their own settings for each of the different applications. Just change from one user to another and all of those pesky settings will change as well.
    Just a thought…
    Tom
