Activity Forums Adobe After Effects Expressions Changing Rotation In Offset
  • Changing Rotation In Offset
    Posted by Liran Lin on May 25, 2020 at 10:27 am
    I have a COMP with layers that i Can Control there Z Deph and X and Y Position, But i Cant Change there Rotation with a CONTROLLER and with a little Offset in Between them.
    I’m Trying to do 2 things.
    1. To change to rotation of multi layers with a Little offset in between them, and connecting to a rotation controller so i Could the Value of the offset.
    2. I would like to make a Delay in the Position and Rotation in the layers Which will follow the Main Layer After Im making a Keyframe animation for the main layer.
    I Hope i Explained myself OK.
    Thanks in advance
    Liran
    //Position controller
    z = (index-1)*thisComp.layer("CONTROL").effect("Z")("Slider");
    x = (index-1)*thisComp.layer("CONTROL").effect("X")("Slider");
    y = (index-1)*thisComp.layer("CONTROL").effect("Y")("Slider");
    [value[0]+x,value[1]+y,value[2]+z];
    Robert Müller replied 6 years, 3 months ago 2 Members · 1 Reply
  • Robert Müller
    May 26, 2020 at 9:37 am
    First for the delay, you should reference the position of your original layer like this:
    delay=0.5; //delay in seconds
    mainPos=thisComp.layer("Main_layer").transform.position.valueAtTime(time-delay);
    [mainPos[0]+x,mainPos[1]+y,mainPos[2]+z];
    And for the rotation its pretty similar with angle controlls instead of sliders (nore: I used the orientation property so that I only have one expression for all the angles)
    //Rotation controller
    rotX = (index-1)*thisComp.layer("CONTROL").effect("rot.X")(1);
    rotY = (index-1)*thisComp.layer("CONTROL").effect("rot.Y")(1);
    rotZ = (index-1)*thisComp.layer("CONTROL").effect("rot.Z")(1);
    mainRot=thisComp.layer("Main_layer").transform.orientation.valueAtTime(time-delay);
    [mainRot[0]+rotX,mainRot[1]+rotY,mainRot[2]+rotZ];
    Note that if you have a controll layer and a Main layer, you might have to change the index calculation, depending on how your layers are arranged.
