Activity Forums Maxon Cinema 4D Changing rolling emitter to pyrocluster
  • Changing rolling emitter to pyrocluster
    Posted by Jack Sewell on November 30, 2010 at 2:05 pm
    Hi there,
    I’ve been trying to change the rolling emitter preset in R12 to spew out pyroclusters instead of the bump mapped spheres.
    There doesn’t seem to be an emitter as such, just a Particle Geometry. The bump mapped sphere is present in the object panel, but I can’t find where it is mapped to an emitter!
    Has anyone been through this process?
    Many thanks……
    Adam Trachtenberg replied 15 years, 5 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    November 30, 2010 at 3:32 pm
    If you click on the rolling emitter null and look in the attributes manager you’ll see the user data fields that are used to control it, including a “Shape” field that defines the object being emitted.
    To convert it to pyrocluster you would:
    1. clear the aforementioned shape field;
    2. create a pyrocluster volume shader;
    3. create a pyrocluster material;
    4. create an environment object;
    5. place the volume shader on the environment object;
    6. place the pyrocluster material on the TP Particle Geometry object.
