Activity › Forums › Adobe Audition › Changing reverb on 1 clip over time in a multitrack sequence
  • Changing reverb on 1 clip over time in a multitrack sequence
    Posted by Craig Ricker on January 31, 2013 at 4:58 am
    Ok so heres what I wish to do:
    Edit entire film in premiere.
    Create a SFX track from soundtrack pro.
    Then do a final mix down via sending sequence to audition.
    I would like to apply effects to various clips and fade these effects on and off.
    How do I go about animating the effects on and off on only a couple of clips? Do I still have to apply the effects to an entire track and then automate on that track?
    Angelo Lorenzo replied 13 years, 8 months ago 2 Members · 1 Reply
  • Angelo Lorenzo
    January 31, 2013 at 8:13 am
    In Multitrack, effects are per track. Add effects to your rack and turn the wet/dry mix to 0%. You can then turn on the effects mix as an automation envelope on each clip to turn it on from its default position of 0% wet. You can use this as a hard on/off and actually mix in the effect with any of the available effects parameters for a better blend.
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
