Activity › Forums › DVD Authoring › Changing Region on DVD Player
Posted by Karl Arndt on September 25, 2005 at 5:23 pmDear fellow Cows, Could someone tell me if it is possible to play a DVD that has a european region code on a US player?
Sincerely, KarlKarl Arndt replied 20 years, 11 months ago 3 Members · 6 Replies -
Noah Kadner
September 26, 2005 at 12:50 amNot unless the DVD player is region free- most aren’t. But you could most likely play it on a computer that allows its region to be changed. Some only let you change a few times so be cautious.
Noah
Karl Arndt
September 26, 2005 at 4:31 pmHey Noah, thanks for taking the time to respond. I thought the answer was as you stated. I hope the region thing goes away soon.
Sincerely, Karl -
Noah Kadner
September 26, 2005 at 4:53 pmNot likely- it’s built into the DVD spec and part of copyright control.
Jason Casey
September 26, 2005 at 9:39 pmsome players have hacks that can make them region free check out http://www.videohelp.com and look up your player…maybe you’ll get lucky.
