Activity Forums VEGAS Pro Changing recorded level
  • Changing recorded level
    Posted by Doyal Gudgel on March 5, 2012 at 12:56 am
    I can change the volume playback level of course but can I change the recorded level. What I mean is one part of the video has been recorded at one level and another at another level. I can isolate those sections of course for editing purposes so if I could isolate then bring the volume up to the level of the other section is that is what I should do. Can this be done?
    Doyal Gudgel replied 14 years, 5 months ago 3 Members · 4 Replies
  • Mike Kujbida
    March 5, 2012 at 1:59 am
    Click anywhere on the audio track and press the ‘v’ key to add a volume envelope.
    Then double-click the line 4 times to add 4 points.
    Raise or lower the level by dragging the line between points 2 and 3 higher or lower.
  • Doyal Gudgel
    March 5, 2012 at 5:52 pm
    OK Thanks. I’ll get right to it.
  • Tannie Low
    March 22, 2012 at 3:32 pm
    You could also split the audio tracks and adjust gain on each individual piece.
  • Doyal Gudgel
    March 22, 2012 at 5:06 pm
