Activity Forums Adobe Premiere Pro Changing project settings?
  • Changing project settings?
    Posted by Danny Winn on February 10, 2013 at 6:52 pm
    Im working in PPro CS4, I created a project in DV widescreen then added tons of clips and music but now I’d like to see if it would be better as 4.3 standard becaus some of my pics and clips are not 16:9. Is it possible to change it to 4.3 aspect ratio to see how it looks without starting over?
    Ann Bens replied 13 years, 7 months ago 3 Members · 4 Replies
  • Angelo Lorenzo
    February 10, 2013 at 7:03 pm
    Not likely, if I recall. You can’t with the newer versions.
    It may be easier, if you do it often, to design a mask OR you could create a new sequence, select all your clips from the old sequence, and copy/paste them to the new sequence.
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
  • Danny Winn
    February 10, 2013 at 7:05 pm
    Darn, that’s what I thought. I will try your suggestion, thanks much.
  • Danny Winn
    February 10, 2013 at 7:14 pm
    Hmm? I created a new sequence in PPro 5 in 4.3 aspect, imported all clips but how do I get them back onto the timeline in the original sequence. Copying from PPro 4 and pasing to PPro 5 does not seem to work. Any suggestions?
  • Ann Bens
    February 10, 2013 at 9:30 pm
    Import the project from CS4 into CS5 then make a new sequence and copy/paste from old sequence.
    Adobe Certified Expert Premiere Pro CS6
    Adobe Community Professional
