Activity › Forums › Adobe Premiere Pro › Changing project settings after completion?
  • Changing project settings after completion?
    Posted by Dusted on September 25, 2006 at 9:00 am
    Hi, I’m very new to Premiere and seems to have made quite a big blunder in my enthusiasm to get started. I have just completed a project that I’m quite happy with and spent alot of time on. The project has been created using the DV Pal profile, but I actually want the exported movie to be a resolution of somewhere in the region of 1152×864 (intended viewing being only on PC). However when I now go into the project settings I seem to be locked to the DV Pal project profile, and quite a few on the options are greyed out. Is there any way I can increase the resolution and acheive the required output I’m after? I really wouldnt want to have to start from scratch again. Any help with this would be very much apreciated.
    Dusty.
    Steven L. gotz replied 20 years ago 3 Members · 2 Replies
  • Robertp
    September 25, 2006 at 4:54 pm
    You can open a new (blank) project at your desired settings. Then import your old project into it. The framing will change a bit though.
  • Steven L. gotz
    September 26, 2006 at 5:53 pm
    Exporting and editing sizes are two different things. Export your PAL frame to a bigger size, but remember, the pixels are not there. To get them, you have to create them in software. The quality diminishes.
    Steven
    https://www.stevengotz.com
