Activity Forums Apple Final Cut Pro Legacy Changing project settings
  • Changing project settings
    Posted by Jon Sletto on September 1, 2010 at 7:10 pm
    Hi
    Ive started a project where Im using 1920×1080 video shots, pictures and P2 shots with 1440×1080 res. In the end Its also going to be parts of 3D motion animation in the prosjekt.
    Initially I put my project settings to 1440×1080. Well into the project I discover that a 1920×1080 resolution will suit the project much better. Can I change the project settings now when I edited more than half of my project. How will this movie clips that initially was filmed in 1920×1080 be effected?
    Im sorry If im unclear in my quiestion. English is not my native language.
    Thanks upfront to all that will shear theire view on this.
    All the best
    Jon
    John Fishback
    replied 16 years ago
    3 Members · 2 Replies
  • Shane Ross
    September 1, 2010 at 10:19 pm
    Is this PAL DVCPRO HD? 1080 DVCPRO HD is 1280×1080…not 1440×1080.
    And since the footage is not full raster 1920×1080…but THIN raster that is stretched out (very normal for anamorphic formats…and they are common)… why do you want to switch to full raster? You won’t gain anything, as the footage is still thin raster…and you will just have to render everything when you are done.
    Shane
  • John Fishback
    September 1, 2010 at 10:22 pm
    Try it and see. Make a new sequence 1920×1080, then copy all the tracks in your current sequence, and paste them into the new sequence. Then you’ll see the result. FCP doesn’t scale well so if you have to resize a lot of clips you may not like the results. In the future it’d be a good idea to convert all your footage to 1920×1080 first, then edit. I’d use Compressor to do that. And you’d also make your graphics the same size rather than resize them.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
