Activity Forums VEGAS Pro Changing position of sound
  • Changing position of sound
    Posted by Jeff Spricenieks on October 26, 2010 at 1:06 am
    Hi all.
    I’m using Sony Vegas 9 Pro, and was wondering if it’s possible to change the positional sound to match movement on screen, for example, using a sound clip for a car passing, but make the sound follow the car front left to right.
    Is it possible or is there another program I should be looking at ?
    Mike Kujbida replied 15 years, 10 months ago 3 Members · 2 Replies
  • Bill Mash
    October 26, 2010 at 3:17 am
    Add a Pan envelope to the Audio track for the stereo affect your looking for. Vegas also supports 5.1, to enable this change your audo property in your Veg file to 5.1.
  • Mike Kujbida
    October 26, 2010 at 3:23 am
    edit: You learn something new every day 🙂
    Do what Bill suggested for a Pan envelope as it’s much easier.
    Position your cursor at the beginning of the event.
    Click the “Animation Settings” button in the audio track header and select “Show Automation Controls”.
    A different symbol should appear in the Pan button.
    Slide the Pan button all the way to the left and a red line will appear on the top of the audio track.
    Position the cursor at the end of the event and slide the Pan button to the right.
    The red line will now drop to the bottom in a curve shape.
    This curve can be keyframed like you would a volume envelope by double-clicking on it to add points and dragging them as desired.
    You can also right-click on it and choose linear fade, fast fade, etc.
    That’s all there is to it.
    Remember to add another point at the end of the event, right-click it and choose “Set to Center” or everything else on the track will be panned hard right.
