Activity Forums Apple Final Cut Pro Legacy Changing opacity on fade transitions
  • Changing opacity on fade transitions
    Posted by Ben Macdonald on June 21, 2010 at 11:28 am
    Hi there,
    I am trying to run back-to-back fade-in fade-out transitions, so that shots fade from and back into black. I have no problem doing this. What I do have a problem with is adjusting the fade so that it begins JUST BEFORE the shot, as opposed to running with black for a while. If I change the duration of the fade, this simply means the shot comes too quickly into focus, defeating the object.
    So, what I want is to cut the fade, or change its entry opacity value, so as to remove the excess black at the beginning and end.
    Many thanks for any help,
    Ben
    Joey Burnham replied 16 years, 2 months ago 3 Members · 3 Replies
  • Chris Tompkins
    June 21, 2010 at 12:44 pm
    Instead of applying a fade trans – keyframe it urself
    Chris Tompkins
    Video Atlanta
  • Ben Macdonald
    June 21, 2010 at 1:05 pm
    Thanks for this. Sadly I am a relative beginner with FCP, could you briefly explain how, or point me to a tutorial if that’s OK? Cheers, Ben
  • Joey Burnham
    June 21, 2010 at 4:47 pm
    Use the pen tool on the layer itself. Make sure you have clip overlays turned on. (Option W)
    Joey
