Activity Forums Adobe After Effects Expressions changing opacity based on scale of layer
  • changing opacity based on scale of layer
    Posted by Ben Christie on July 12, 2016 at 10:53 pm
    Hello all,
    Another brain buster.
    I am scaling a layer from 100 – 120 every so often and rather than animate the opacity I want to use an expression.
    When scale is 100 I want the opacity to be at 100, when scale is at 120 I want the opacity to be at 45.
    I’m sure there is an fairly simple way to do this.
    Any help would be much appreciated.
    Dan Ebberts replied 10 years, 1 month ago 2 Members · 3 Replies
  • Dan Ebberts
    July 12, 2016 at 11:07 pm
    This should work:
    linear(scale[0],100,120,100,45)
    Dan
  • Ben Christie
    July 12, 2016 at 11:16 pm
    This works perfectly!
    Why do I start the expression with linear? Just curious to understand how it actually works.
  • Dan Ebberts
    July 13, 2016 at 12:30 am
    linear() is an easy way to convert one range to another in a linear relationship. There are other interpolation methods available: ease(), easeIn(), and easeOut()–but linear() seemed best suited to your needs.
    Dan
