Activity Forums Maxon Cinema 4D changing one material to another material on an object
  • Brian Jones
    February 21, 2013 at 9:50 pm
    here’s a test of a shader that’s based on the example render from that page. Just uses noises with animated Clip ranges. It’s a fast try so not as nice but the general idea is there I think.
    5504_shadertest.c4d.zip
  • Dean Chapman
    February 22, 2013 at 12:02 am
    Oh very cool Brian. Thank you again for the hundredth answer to my hundredth question 🙂
    I wonder…is there a way to drive the alpha channel with some sort of viewport visible reference object…like when you use an effector in mograph. Perhaps through xpresso or set driven keys?
  • Brian Jones
    February 22, 2013 at 2:34 am
    a HUD control of the alpha would have to be controlling a channel shader in the alpha (since alpha doesn’t have a ‘brightness’ slider like transparency) but definitely it’s easy. Just add a User Data channel to something (probably the object or even the xpresso tag) and run that to the channel you want to control in xpresso.
  • Dean Chapman
    March 2, 2013 at 10:19 pm
    Never thanked you for this tip…..Thank You!
    -d
  • Brian Jones
    March 2, 2013 at 10:20 pm
