Activity › Forums › VEGAS Pro › changing mp4 format
  • Roger Bansemer
    February 20, 2010 at 7:47 pm
    Highlight the clips you want to convert and go to “Save” and then “Render as” from there you can choose many formats you can save the clips. Be sure to check the box “render looped region only”. If you don’t do that the entire project will be rendered as saved.
