Activity Forums Panasonic Cameras changing Meta Data on P2 cards
  • changing Meta Data on P2 cards
    Posted by Kelsey Smith on September 11, 2007 at 8:06 pm
    I was wondering if anyone else has run into this. If you change the Meta Data (i.e. user name info) on a P2 card with P2 Log Pro and then try to ply it back on the HVX-200 camera, you get an error and none of the clips will play. All the clips play fine with Log Pro, but they won’t play on the camera. Is there a work around for this or a possible fix??
    Kelsey W.
    Kelsey Smith replied 18 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
