Activity › Forums › Maxon Cinema 4D › changing mesh without screwing up texture
  • changing mesh without screwing up texture
    Posted by Donald Mitchell on June 21, 2011 at 1:12 pm
    I have a model of a carton, I applied a texture to it as a flat plane and generated UV co-ordinates. Then I folded it up to form the carton. The texture is perfect. Now I want to tweak the points at the corners of the carton to improve how the folds look. When I do though the texture distorts in those areas.
    I assume I’d need to tweak the UV points as well in bodypaint, but I’m pretty clueless about using it.
    Is there a way to make this work that’s simple, or can someone point me in the direction of a good UV tutorial that’s related to boxes or packaging and not creature or character design?
    Thanks for any help.
    Adam Trachtenberg replied 15 years, 2 months ago 3 Members · 3 Replies
  • Adam Trachtenberg
    June 21, 2011 at 3:40 pm
    It is a UV mapping problem, as you surmised. Unfortunately there’s no quick fix for it. I don’t know of any tutorials specifically addressing packaging-type stuff, but principles for UV mapping characters apply to any type of UV mapping.
  • Blain Klitzke
    June 23, 2011 at 6:01 pm
    I am having a potentially similar problem. I am trying to separate wheels from a car mesh so that they can be animated. When I make changes to the mesh (ie: disconnect and delete polygons to isolate the wheels) the textures get fragged and funky: where there was once a smooth material, every polygon seems to be reflecting in different directions?
  • Adam Trachtenberg
    June 23, 2011 at 8:34 pm
    Yes, sounds like another UVW issue. Some modeling operations, like the knife tool, don’t mess up UVs. Others, like extrusions, do.
