Activity Forums Maxon Cinema 4D Changing materials on cloners
  • Changing materials on cloners
    Posted by Jack Sewell on March 13, 2011 at 9:27 pm
    Hi there,
    I’ve set up a scene (find attached) with some glass cases containing an image, which have been put into a cloner repeated in z space. There is a master case which animates from left to right which is controlling an inheritance effector, which is in turn controlling the cloners.
    All sounds a bit complicated…..see the project file. (R12)
    The idea is to have a camera moving through a set of panels either side which turn to face the camera is it moves through them. I wanted to set this up so that I could use it to present a bunch of images.
    The inheritance effector does a great job of staggering the animation of each independent panel, however the problem is that as they are set up as cloners, I have the same image on each of them.
    I wondering if there is a way of changing the materials of each panel whist keeping the set-up.
    Or is this just impossible?
    Many thanks for any help! 🙂
    1753_glasscases.c4d.zip
    Jack Sewell replied 15 years, 6 months ago 2 Members · 2 Replies
