Activity Forums Maxon Cinema 4D changing materials during animation
  • changing materials during animation
    Posted by Bruce Rudolph on October 26, 2009 at 6:08 pm
    I was wondering if there’s a way to change materials on an object during an animation?
    Even better, is there a way to cross dissolve between two materials
    (each .png files in the color channel), during an animation.
    Even better still, and what I REALLY want, is to do in a mograph cloner, driven by linear falloff????
    Any of you expresso wizards have an idea?
    Bruce
    Adam Trachtenberg replied 16 years, 10 months ago 2 Members · 3 Replies
  • Adam Trachtenberg
    October 26, 2009 at 9:59 pm
    For Mograph:
    * create a material with the mograph multi-shader in the color channel;
    * place the start bitmap in the first slot and the second bitmap in the second slot;
    * assign the cloner a plain effector with all parameters except “affect color” turned off;
    * set the effector to linear falloff and animate position.
    Unfortunately that won’t, by itself, do any cross fading. The clones will be either one bitmap or the other.
    As a workaround, you could do the following:
    * In a compositing application, record an animation of the two bitmaps crossfading one into the other;
    * Load the movie file into the first multi-shader slot and delete the second if you’ve already filled it;
    * Hilight the first slot (Shader 1) and click the “to layers” button.
    That will create a separate layer for each frame of your animation. Now when you move the effector it should do a cross fade.
  • Bruce Rudolph
    October 27, 2009 at 12:59 am
    Hey Adam, Thanks for the info.
    I attempted to follow the first part of the instructions To get a multi shader to swap materials using a plain effector. Thats exactly what I need. I wasnt able to get it to work. There’s quite a few options in the shader as well as the effector. I was wondering if you could have a look at the project file that I attached and see where I went wrong.
    Thanks again,
    Bruce
    File link
    Adam Trachtenberg
    October 27, 2009 at 3:05 am
    Happy to look at it but I’m getting a 404 on the link.
