Activity Forums Adobe Premiere Pro Changing length of DISSOLVE
  • Changing length of DISSOLVE
    Posted by David Smooth on September 13, 2016 at 11:52 pm
    Is there a way to change the default fade length of a dissolve?
    I have say 20 clips that need a 1 sec dissolve between them rather than the standard 5 seconds and would rather not have to individually change each fade’s length manually.
    Cheers in advance,
    -Dave
    Duke Sweden replied 9 years, 11 months ago 2 Members · 1 Reply
  • Duke Sweden
    September 14, 2016 at 7:00 pm
    Yes, under edit>preferences>general you can change the Video Transition Default Duration. You can also set it for audio as well. In seconds as well as frames (i.e. 1 second or 24 frames)
