Activity Forums Apple Final Cut Pro Legacy Changing L3 DX rates efficiently
  • Changing L3 DX rates efficiently
    Posted by Babcut on February 12, 2006 at 11:11 pm
    I have a sequence which is covered in subtitles and I need to change the fade in/fade out
    rate for all of them. Does anyone have an efficient suggestion? I tried changing my
    default transition and dragging the track to “Overwrite with Transition’ but that had no effect.
    Real Life is Your Best Entertainment Value
    Babcut replied 20 years, 6 months ago 3 Members · 5 Replies
  • Jeremy Garchow
    February 13, 2006 at 12:48 am
    I’m not exactly sure if this will work, but it’s worth a shot. First, duplicate the timeline and work from the duplicate so that you’ll have a good copy of the timeline in case this doesn’t work.
    It sounds like all of your subtitles are in the same track, if this is so select all clips in that track (and only that track) control-click a TRANSITION, not the subtitle clip in the track and select the duration option from the drop down menu. Change the duration once the dialog box pops up.
    Jeremy
  • Babcut
    February 13, 2006 at 1:12 am
    I tried this but it didn’t work. Any other thoughts are appreciated.
  • Jeremy Garchow
    February 13, 2006 at 2:27 am
    Sorry, I thought this might work. One by one might be the only way. Or have a look at this:
    https://www.xmedit.com/
    Jeremy
    G5 Dual 2Ghz <> 4GB RAM <> FCP 5.04 <> Kona 2
    ATTO 42XS <> Huge Systems 4105 Fibre
    OS 10.4.2 <> QT 7.0.3
  • Frank Nolan
    February 13, 2006 at 7:47 am
    Are the fades for the subtitles created with a transition effect or were they created with opacity keyframes?
  • Babcut
    February 13, 2006 at 11:24 am
    I used a transition effect. With keyframes I probably could change it globally.
