Activity Forums Adobe After Effects Expressions Changing Keyframe Time Through Expressions
  • Changing Keyframe Time Through Expressions
    Posted by Amir Aizat on August 7, 2016 at 6:01 pm
    Hello, I’m trying to create a template for my team’s video editors working with Premiere Pro.
    It’s supposed to be a transition with adjustable speed by keying s, m, or f in Premiere’s Live Text templates feature.
    English is not my first language, and I am a rookie with expressions (self-taught to boot) so please bear with me.
    The transition has 4 keyframes, 2 in and 2 out. Fast transition will result in -1s for keyframe 2 and +1s for keyframe 3 and the opposite for slow transition. Medium speed will not change the timing of the keyframes. The reason I want to manipulate keyframes instead of using the ease expression is because I want to preserve my speed graph.
    So far I came up with this:
    //Transition Speed
    var mod2 = thisComp.layer("Speed (s/m/f)");
    var mod2spd = mod2.text.sourceText;
    var ti = thisComp.layer ("Transition A");
    var tp = ti.transform.position;
    var tpk2 = tp.key(2).time;
    var tpk3 = tp.key(3).time;
    if (mod2spd == "s" || mod2spd == "S")
    tpk2+1, tpk3-1
    else if (mod2spd == "m" || mod2spd == "M")
    tpk2, tpk3
    else if (mod2spd == "f" || mod2spd == "F")
    tpk2-1, tpk3+1
    else
    tpk2, tpk3
    valueAtTime
    Obviously I received the orange error message but the error message isn’t helping either, it says “Error at line 0 in the property “Position” of layer 3 (‘Transition A’) in comp ‘Helper Transition’. Object of type Function found where a Number, Array, or Property is needed., an expression was disabled as a result of an error.”
    Can someone explain my mistake and how do I achieve what I wanted to make?
    Thank you.
    Amir Aizat replied 10 years, 1 month ago 2 Members · 2 Replies
  • Dan Ebberts
    August 7, 2016 at 6:52 pm
    You can’t change keyframe times with expressions, but this position expression for your transition layer should do what you want:
    mod2spd = mod2.text.sourceText.toLowerCase();
    t1 = key(1).time;
    t2 = key(2).time;
    t3 = key(3).time;
    t4 = key(4).time;
    doingIn = time < (t2+t3)/2;
    t = time;
    if (mod2spd == "s"){
    if(doingIn){
    t = linear(time,t1,t2+1,t1,t2);
    }else{
    t = linear(time,t3-1,t4,t3,t4);
    }else if (mod2spd = "f"){
    if(doingIn){
    t = linear(time,t1,t2-1,t1,t2);
    }else{
    t = linear(time,t3+1,t4,t3,t4);
    valueAtTime(t)
    Dan
  • Amir Aizat
    August 7, 2016 at 7:03 pm
    Hi Dan,
    That is amazing! I’ve learned something new today, and I’ve always learned from your other examples.
    Many thanks!
