Activity › Forums › Adobe After Effects › Changing Keyboard Shortcuts in CS6?
  • Changing Keyboard Shortcuts in CS6?
    Posted by Crys on February 19, 2013 at 3:41 pm
    Hello,
    I have been searching how to change my keyboard shortcuts for AE CS6 and cannot find a solution. I found a script through Adobe Exchange created by Jeff Almasol, but when I open the script in CS6, the changes do not take place. I have tried restarting AE, but still does not work. Here is the script I am referring to:
    https://www.adobe.com/cfusion/exchange/index.cfm?event=extensionDetail&extid=1698043#addreview
    The main shortcuts I want to change are “Add to Render Queue”, “Replace Footage File” and “Hide After Effects”. Is there an easy way of doing this?
    I am working on a Mac Version 10.8.2.
    Thanks for your help!
    David Cabestany replied 12 years, 6 months ago 5 Members · 13 Replies
  • 13 Replies
  • Todd Kopriva
    February 19, 2013 at 4:18 pm
    If the script isn’t working for you, you can change the shortcuts directly by modifying the text file that defines them. It’s in the same folder as the preferences file. You can open that folder by clicking Reveal Preferences In Finder button in the General pane of the Preferences dialog box.
    After Effects team blog
  • Ridley Walker
    February 19, 2013 at 4:33 pm
    One other method of changing keyboard shortcuts on a Mac is to use the System Preferences for the Keyboard. I’ve added several shortcuts for items that don’t have them.
  • Crys
    February 19, 2013 at 5:22 pm
    I am not seeing this text file you’re referring to. Where is this Preferences file? I went to Finder and opened the System Preferences and clicked on the General tab, but I’m not sure what I’m supposed to adjust??
  • Crys
    February 19, 2013 at 5:23 pm
    Thanks for the tip! I tried this, but it did not work for me. Perhaps because we have Creative Cloud??
  • Ridley Walker
    February 19, 2013 at 5:25 pm
    Are you sure you selected the app before modifying the keyboard shortcuts?
  • Crys
    February 19, 2013 at 5:34 pm
    Yes, I believe so. Here is the screen shot: https://f1.creativecow.net/5481/ae-keyboard-shortcut
    (hope that link works)
  • Ridley Walker
    February 19, 2013 at 6:26 pm
    You need to enter the menu *exactly* as it is written in After Effects. Here is the Replace Footage > File… command.
    See:
  • Crys
    February 19, 2013 at 9:31 pm
    Thank you! The “Replace the file” shortcut change worked!
    But I still can’t get “Add to Render Queue” to work. I see in the shortcuts that it’s the command I changed it to, but it’s still not working. Oh well… guess I’ll just deal with it!
  • Ridley Walker
    February 19, 2013 at 10:13 pm
    I just tried it and it works for me. Check your spelling, make sure there a no extra spaces between words etc.
    It must match EXACTLY what is in the After Effects menu. AND you must modify After Effects Preferences by un-checking “Use System Shortcut Keys” in General Preferences.
  • Todd Kopriva
    February 20, 2013 at 12:12 am
    Open the Preferences dialog box in After Effects, not the Mac OS system preferences. Then click the Reveal Preferences In Finder button at the bottom of that dialog box.
