Activity Forums Maxon Cinema 4D Changing inner and outer color of text
  • Changing inner and outer color of text
    Posted by Stephen Turcotte on June 29, 2011 at 2:55 am
    I’ve created text with an array of lightbulbs inside of it, sort of like a marquee above a casino. I would like to have a reflective texture on the inside to reflect the lightbulbs and a matte finish on the outside. Is there any way to separate the inner and outer surfaces? So far I’ve only been able to add different textures to the fillets and caps.
    Thanks.
    Stephen Turcotte replied 14 years, 10 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    June 29, 2011 at 3:28 am
    You can use two separate materials, specifying front and back in the texture tags’ “side” parameter.
  • Stephen Turcotte
    June 29, 2011 at 1:51 pm
    Great! thanks so much.
