Activity › Forums › Adobe After Effects › Changing individual position values in a series of keyframes
  • Todd Kopriva
    August 28, 2009 at 9:21 pm
    You can select all of the keyframes and drag the x or y values in the Timeline panel. (See this page.)
    Also, you can separate Position into its components if you’d rather work that way.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Greg Neumayer
    August 28, 2009 at 10:30 pm
    You could link the x or y to another value such as an expression slider. I do this sometimes to attenuate the overall effect of my keyframes. For example, I had a flickering light that I decided I wanted to fade up, so I linked that light level (which contained many keyframes) to an expression slider, and keyframed that slider with a start value end value keyframe.
    Antifreeze Design
    https://www.antifreezedesign.com
