Activity › Forums › Boris FX Particle Illusion › changing immiters
  • Jim Scott
    March 24, 2006 at 5:41 pm
    See the PI Help files, Tutorial 4 – Replacing an Emitter:
    First, select the library emitter that will replace the stage emitter. Then R-click on the stage emitter and select Replace. You’ll be asked to confirm the replacement:
    After clicking Yes, you’ll see the Replace Emitter Options dialog which allows you to determine which stage emitter properties to save, and which to replace with the library emitter properties.
    Checked properties will preserve the values from the existing stage emitter, unchecked ones will use the property values from the library emitter.
  • Steve White
    March 24, 2006 at 9:57 pm
    sust this right clich emmiter and goto export position data to save your data as a text file then add a new emmiter to the stage and import back your emmiter file…………thanks anyway.
